Most of the day was spent running wires, drilling penetrations in the rear rib and mounting the main instrument panel. The panel was designed to hinge forward slightly to make it less difficult for any maintenance that's required behind the panel. I plan on having some pretty good size service loops in the wire bundles and the pod is quite deep. I'll install a cross brace between the uprights inside the pod to fasten the bundles to.
