Brief Description: Installing the Floorboard and Center Console
After the belly strobe, transponder antenna and temp probes were wired I installed the floorboard for the last time (I hope). I made the center console with the side removable for easy access for wiring (design inspired by Bill). I used fairly large extrusion to form the frame for the console so it's quite sturdy. I put a good layer of black sealant down before I riveted it to the floor.
As you can see below, marking all of the wires is a neccessity. They all start looking the same the more you add.
