I've decided to replace the motorcycle style collective grips supplied with the kit with the Ray Allen grips shown below. The grip with the multiple switches will of course be installed on the left side. I've yet to decide on each switch function. I'll probably use the 3 switches on the cyclic for the radio functions. The last photo shows two different styles of cockpit lighting that I'll be installing. The first unit is a traditional style cockpit light with high intensity white LED's. The round unit next to it is an "eyeball" style bulb unit. The 'eye" can be set in any position. These are also available from Stein Air.
