I have finally gathered all of the avionics/electronics (with the exception of the portable GPS). The first photo shows the Lamar control unit and it's harness. The second photo is the Becker transponder and the ant. and cabling. I modified the harness from the Dynon D100 EFIS so I could use the D100's built-in encoder. I also had to add a converter to the harness. The third photo shows the VHF antenna, the XCOM radio/intercom, instructional DVD, the Remote Module that allows for remote control of the radio from the stick, harnesses and antenna lead.
