Safari Helicopter Construction
Date:  2-24-2007
Number of Hours:  3.00
Brief Description:  Cargo Sling Hook
I got a great deal on a sling line hook on Ebay. All it needed was sand blasting and a coat of paint. The hook has a flange that sits on a bearing inside the housing. I cleaned and greased the bearing and now it works like new. I still need to come up with a method to secure the end of the rope to the hook fitting.
As received
As received
After painting
After painting
The back end of the housing is threaded and removes to access the bearing
