It's been difficult to find time during the holidays to work on the project. I did get some time to complete the assembly of the ground handling wheels. I thought it may make it a little easier to move the cabin around while it's at the paint shop. The first photo shows the parts that make up the assembly. I applied a dry film lubricant to the outer diameter of the shafts and used the fill and drain method to apply primer to the inside diameters. The 2nd and 3rd photos show the wheels in the "stowed" position inboard of the skids. I've seen photos with the wheels mounted outboard of the skids also. I figure that there will be less chance of tripping over them on the inside.
