Brief Description: Located Belly Anti-Collision Strobe
I decided to install a second flashing strobe on the belly. This particular beacon does not require a seperate power supply and is quite easy to install. Like the pitot, I will install a 3" diameter doubler behind the belly pan to sturdy up the installation. I also plan to install a pulsing unit on landing light to increase my visibility to other aircraft. I fly in and out of busy Boeing Field and a lot of airplanes don't look for helicopters.
