Safari Helicopter Construction
Date:  6-24-2006
Number of Hours:  3.50
Manual Reference:  Page 62
Brief Description:  Built & Installed RT. Seat Panel
I prepared the cardboard template and then cut the sheet metal pattern for the right side seat panel. I used the brake to form the 90 degree flange, then finished the forming using a steel bar the same diameter as the seat brace and a vice with rubber faced jaws. It figures that I'm finally starting to get the hang of this sheet metal stuff just as I'm nearly done with the cabin construction.
Final fit-up
Final fit-up
Forming with the vise
finished panel
finished panel
