Safari Helicopter Construction
Date:  6-11-2006
Number of Hours:  8.25
Manual Reference:  Page 64,
Brief Description:  Rear Seat Panel and Center Collective Panel
I patterned and cut out the rear seat panel. When you measure for this panel keep in mind that the panel edges are not straight, but taper to the top edge. This panel is thicker than most interior panels and I was glad to find that the air shears handled the cutting with no problem. I used two seperate pieces to form the "box" that encloses the co-pilots collective. I found this design on Bill's website. If you are building a Safari this site is a must-see. Check it out at: http://www3.telus.net/public/wsm/C-GOEZ.htm
Rear seat panel fitted
Cutout for collective control
Surround for center collective
