Secure wire bundles Install tranny vent tube Install temp sender in tranny Install circuit breaker for the Lightspeed unit Phase the electronic ignition system (determine which coil is firing to which cylinders) Cover the oil cooler lines that pass close to the cylinders with fire sleeve.
