Installing the magneto's ignition harness Gapping, installing and torqueing the spark plugs Routing the high voltage lines for the Plasma III ignition system Installing the Plasma III harness Installing each CHT probe Installing the left side of the shroud Cotter-pinning the engine mount bolts Installing the left side's rocker covers and drain hose Installing the crankcase vent tube Initial fitting of the oil sump Mounting of the left fuel tank in preparation of installing the fuel probes
