I finally had time to unpack and inspect the transmissions. Everything was packed in very rugged shipping containers and all components were well protected.
I did note that one of the bolts where the lower mast attaches to the upper transmission casing was allowing gear oil to leak out when the transmission was laying on it's side. A call to the factory determined that adding a little silicone sealant to the bolt shank should solve this problem.
