Brief Description: Adding Nutplates to Heat Collector
The plans don't really show any nutplates used to fasten down the heat collector to the shroud, but I've noticed several builders have added these. Without them the only thing holding the collector in place would be friction from the contact points top and bottom of the oil cooler and the SCAT tubing fastened to the output flange.
