Brief Description: Installing the Intake Manifold Runners
I cut the steel inserts for the intake hose, sanded the ends and touched up the primer before installing. I had previously primed the tubing inside and out. I found that a small dab of silicon grease smoothed onto the inside of the hose allowed the inserts to slide in much easier. I made sure to remove any residue. The steel tubing inserted into the intake hoses will prevent the hose from collapsing
I had the intake runners ceramic coated the same time as the exhaust. I'm missing the hose clamps that were to come with the kit so it will have to wait until next weekend to be completed.
