Brief Description: Installing the Fuel Shut-off Valve and Gascolator
I installed the shut-off valve and used it as the starting point for measurements for the hoses. I may change the hoses out at a later date for the stainless steel encased/teflon lined type, but for now I'll just go with the stock setup.
Routing the fuel lines and components is a fairly simply matter since the system does not use a fuel pump and I chose not to install the primer system due having installed the Lightspeed electronic ignition and to our temperate weather here in the Pacific Northwest. I've yet to use the primer on the R22's that I fly during training.
Connecting fuel supply lines to shut-off valve
Red dust cap on top of gascolator is where the primer system connects
