I decided to incorporate four switches into the pilot's cyclic stick grip. The trigger switch will function as a radio press-to-talk. The three in the top cap (I added one in addition to the two it came with) will control frequency flip-flop, one will scroll through memory channels and one will serve as a governor on-off switch. I found it necessary to trim off the extra protruding terminals from the back of the trigger switch to allow clearance for the wires. The wire bundle was secured for strain relief with a small dab of Locktite Black Rubber Adhesive sealant. I have used this sealant throughout the construction with excellent results. I've yet to find something it won't stick to. The wires were encased in shrink tube for routing back under the seats.
