Brief Description: Tail Boom control Cable and Harness
I want to finish the electrical and be done with it, so I have installed the tail boom to position the tail rotor control cable. I plan on attaching the wire harness for the strobe, tail light and tail rotor gear box chip detector onto this cable.
I see a lot of builers just tie-wrap the control cable to the bottom tube of the boom, but I decided to use a #12 adel clamp on the boom that supports the #6 clamp around the control cable. I'll place these equally spaced down the length of the boom. I plan on tie-wrapping the wire harness to the control cable. I had to order more adel clamps so I hope to finish it up this week-end.
I'll route the control cable through the cabin to the pedals to check the fit, then I'll remove the boom so it's not in the way while the transmission and engine are undergoing final installation. I'll re-install the boom just before it's time to install the main blads.
