Brief Description: Soldering Diodes to Warning Indicator lights
In order for the LED indicator light test circuit to function properly, diodes need to be installed at each light location. I understand that LEDs rarely fail, but I wanted a way to check their function as you would with a press-to-test lamp. The indicators will be tested via a switch on the main panel. There will be a total of 11 indicators.
