When I layed out the design for the instrument panels I included all of the necessary switches, instrument cuttouts and indicator light holes but I forgot about all of the required placarding that needs to be somewhere on the panel. If you look in the pilot's Flight Manual you will find the required markings.
Luckily the panels were not installed yet so I was able to revised the CAD file for each panel and found room to engrave all of the placards with the exception of the Density Altitude chart. I'm thinking about making a small hinged door that attaches to the bottom of the compass mount. I'll just attach a label to it and flip it down when needed (I ended up mounting my compass on the side of the pod).
