Safari Helicopter Construction
Date:  8-11-2007
Number of Hours:  4.00
Brief Description:  Fuel Shut-off Valve Placard
Since the shaft is much longer than the original I supported the end with a grommet. I will mount the placard after the head board is done.I may install a handle shaped guard on each side of the handle to prevent interference with the seat belt. The placard is machined from alum., anodized, painted and then laser engraved.
End of shaft is supported with grommet
