The supplied weight tube will not fit into the front skid mounting bracket without tightly binding, making it nearly impossible to pull out. I'm attempting to enlarge the mount using an abrasize wheel. If I had some way to turn down the OD of the tube I'd try that instead. I don't seem to be making much headway with the sanding, so I may end up making a new mount.
