Brief Description: Applied finishes to detail parts
Finished up priming and application of Dry Lube to all of the cabin controls. Due to the suggestion of another Safari builder, I applied Dry Lube to all of the contact faces of the Slider T's. I am going to remove the outer tube from both of the collectives so I can apply Dry Lube there also. There is no provision made for applying grease to these areas and I want the throttle linkage to be as smooth as possible for the electronic governor.
