Safari Helicopter Construction
Date:  2-16-2006
Number of Hours:  1.50
Manual Reference:  Page #35
Brief Description:  Assembled Cooling Shroud for test fit
Checked the fit and finish of the cooling shroud assembly for the 0-360 engine. Everything lines up perfectly. I will have to construct the carb heat and cabin heat boxes, since they were not precut and formed at the factory. I'll take these parts to work and Alodine and prime all of the bare alum. parts. The plan is to prime all sheet metal parts now and topcoat upon assembly. Maybe by then I'll have decided on a color scheme.FYI: The round object in photo #3 is the new factory design for the oil sump. From all appearances, it looks like 2 end pieces from the fuel tanks were welded together to form the reservoir. My wife says it looks "spacey". I like it.
Detail parts
Detail parts
Assembled shroud
Assembled shroud
Parts after Priming and Black Anodizing
