Safari Helicopter Construction
Safari
Transmission Oil Overflow Reservior
I installed a small reservior to catch oil overflow from the main transmission as it heats up. I drilled vent holes in sides of the plug so it can breath. This unit is normally used as a brake cylinder and can be found at Wick's Aircraft Supply.
Safari Home
1096
Blades
Certification
Flight Controls
Flight Testing
287
Rigging
Special Processes
Weight & Balance
CH-7 Kompress Home
