I spend this day getting the horizontal stabilizer in position. I made sure the fuselage was level in both directions. Once level, I positioned the stab. I had to shim the fuselage brackets so they would touch the brakets on the stabilizer. It is very important to not side load the fuselage brackets. I clamped it in place and measured, measured, and measured to make sure it was square.
