Flipped the fuselage over to install the main landing gear. The main gear had to have grooves filed on the front and the back of the landing gear to fit between the studs of the landing gear mounts. The gear ended up perfectly square! Final installation will happen when the rubber isolation strips arrive. I do not like the rubber strips supplied by the factory so I ordered replacements.
