I had to rearrange my shop to get the work bench to the side wall and out of the middle of the shop. The fuselage need to move to lower saw horses for final assembly. I used 3 wood saw horses and 2"square tube as beams to make sure the fuselage was on a flat surface. I leveled the center channel in both directions and the top longerons of the rear section. The front of the front floor is raised per the plans to provide the correct angle for the firewall, the next step.
