Left fuel tank assemly. Installed the cork strips to protect the tank in th wing and to prevent the tank from moving. Drilled the hole in the end of the tank for the fuel level sender unit. Intalled the sender unit per the manufacturers instructions and sealed the gasket area and mounting screws with proseal fuel tank sealant. Intalled the remaining tank fittings, like the drain valve, pickup line fiting and upper tank plug.
