Brief Description: Vernier Rotax Throttle and Choke cables
Installed the Vernier Rotax Throttle and Choke cables per Vans instructions in Section 49. Added fluids including Aeroshell oil, coolant and premium auto gas. Rolled it out of the hanger and started it for the first time. The idle is running about 2200 rpm so I will need to slow it down to about 1450. Still need to balance the carbs too but in turning off one ignition at a time it seems to working well, dropping about 100 rpm on each. All termperatures were normal.
