Brief Description: Completed Fiberglass bracket for canopy
After many epoxy coats and re-coats, the fiberglass bracket is completed. I removed the canopy to sand the underside and attach the seal per Van's instructions in section 34. This was the part I was most dreading, and so I am very happy it turned out well. As you can see I used a black ink tint to the epoxy since it will show from the underside of the canopy. I intend to paint this the top portion the same color as the airplane.
