Brief Description: Installed the Plexigass Rear Window
Installed the plexiglass rear window loosely with screw, washer and nut hardware. Had my wife, Michelle, crawl into the back (she is much smaller) and add electrical tape per instructions below the plexiglass. I added the tape on the outside (the easy part). Once taped, I added fuel tank sealant between the skin and plexiglass, then we tightened the hardware with her holding my nuts. It worked with no cracks first time, and sealed well! Although when Michelle pulled the tape off the insdie some primer paint came off, so I had Michelle tape off the plexiglass with painter's tape so I could then re-prime the inside panels.
