Brief Description: installed Panel Base and Canopy Ribs
Added nutplates and support brackets to Panel Base per directions and installed behind forward firewall. Added Canopy Ribs to each side.
Note: I did not install the F-1202Bor F-1202K or the nutplates on the bottom lip of the Panel base as these will not be used for the Garmin instrumentation kit. I also did not install the instrument Panels or Glove Compartment as the panels will be different with the Garmin instrumentation kit.
