RANDY'S WEB SITE
Date:  2-4-2015
Number of Hours:  6.00
Brief Description:  Ran brake lines
The last two nights I worked on the brake lines, adding connectors and attaching to brake pedals.
The most time consuming and hardest part was getting the connector inserts and sleeves on the ends. Per instructions I had to boil the ends several times to get them to slip on correctly.
Connections to brake pedals
Brake line forward path
Brake line aft path
Brake line aft path
