Brief Description: Seat Back fabrication and attach
Fabricated, primed and attached the seat backs. After attaching the seats I noticed the right seat was offset 1/2" from the center of the right stick (and seat belt harnesses). I also appeared that much off center compared to the left seat. I first verified I had installed the henges correctly, which I had according to the instructions, and after research on the internet others had noticed the same offset. So I called Van's technical support and they said Van himself had commented on the same issue. They approved changing the direction of the floor henge so it offsets the seat henge by 1/2". This change was made, and centered the right seat perfectly.
