DAVID'S WEB SITE
Date:  4-20-2012
Number of Hours:  3.85
Brief Description:  Finished left HS rivet and started on Right
Today I finished riveting the left HS skin on to the underlying skeletal structure with the exception of the rear spar and inboardmost ribs. I then riveted HS-707 onto the right skin and then clecoed the skin onto the front spar structure.
I then riveted the end of the front spar onto the outboardmostg rib followed by riveting half the rivet on the skin. These are the ventral surface of the HS. I then called it a day. The parts are really starting to look like airplane stuff. This bad boy is cool!!!!
Me riveting the skin on the Left HS
Sample of my flush rivet handywork
Left HS almost done
Left HS almost done
