Brief Description: Countersinked and dimpled the counterbalance weigh
So today I countersinked the counter balance weight and then dimpled the counterbalance rib. Then I bolted on the counterbalance weight to see how she fit together. Not bad, if I do say so myself. I then countersunk the trailing edge spacer. The also came out pretty good. All that is left is to prime the remainder of the skeletal structure and START riveting it together.
counterbalance rib bolted on to the counterbalance rib
