DAVID'S WEB SITE
RV-7/7A
Started the assembly of the VS
Today I began to assemble the Verticle Stabilizer as I finished smoothing the edges, drilling out the holes, acid etching and priming the parts.
I started with riveting together the Rear spar with the doubler and the Rudder brackets. I then riveted together the skeletal structure.
Called it a day.
Rear Spar riveted aft view
Rear spar forward view
VS Skeletal structure riveted
RV-7/7A Home
154
Elevator
25
Empenage Inventory
Vertical Stabilizer
