Brief Description: Removed and replaced stripped bolt
I worked at removing all the bolts which held the right landing gear receiver in place in order to get to the stripped bolt. I finally figured out I could reach it by removing the wooden block at the end of the spar carry-through and reaching in from there. Once I did, it was really easy to access the stripped bolt with a pair of vice grip pliers and hold it while spinning it from the other side. It came off easily! I remounted the landing gear mount and bolted it in without any further problems.
