ROGER'S WEB SITE
Date:  4-30-2008
Number of Hours:  1.50
Brief Description:  Repair stripped screw; stripped a bolt
I was able to find Stainless Steel 8/32 pan head machine screws at Budget Bolt to replace the AN-515-8 screws which keep getting the phillips head stripped out of. I had to die cut a slot in the head of the stripped screw, with the Dremel tool, in order to get it out. I replaced all the screws with the SS ones. I also tried to tighten the rest of the bolts in the carry-thru spar using the tool Zack Massey made for me. I stripped the one on the bottom right and have been unable to get it off to replace it. I will check with Zack or David tomorrow and see if they have any suggestions.
