Removed masking on fuselage, canopy, Wings, canards. Found heat damage to micro bottom of right wing trailing edge. Leveled fuselage; checked engine level. needed to loosen top engine mount bolts. Will need to shim top engine mount locations; also need to check that nose is either centered or about 1-2 deg left of center. Painted contorl surfaces, i.e. aelerons, rudder, elevators. Painted top of tailcone.
