Purchased from Scott & Duane Swing for $1.00 and other valuable considerations. Kit was damaged at the top, forward shell on the sides and behind the canopy location. Scott suggested building a lattice between the conopy and the tail fuselage. A firewall bulkhead, FS 97 bulkhead and FS 122 bulkhead have been installed. Canard has been built in a flat configuration with elevators installed in preparation for Tricycle gear. The main wing has been built with aelerons installed. Vertical stabilizer hotwired, but not glassed. Rudder built. Canopy installed in upper fuselage frame. Received miscellaneous weldments and hardware.
