Dick's Web site
Date:  3-15-2007
Number of Hours:  3.00
Brief Description:  Remove protective coating from left & right airle
I removed the protective coating from the bottoms of the left & right airlerons
I used my heat gun to heat small areas (about 4x4 inches) and then gently peeled off as big a piece as I could. Still small pieces but it worked. Another 2 hours of a truly Zen process on the bottom of the airleron with the wing removed and on a stand.
