Dick's Web site
Date:  1-26-2007
Brief Description:  Tow bar
The two piece clamp on colllar was purchased from McMaster Carr (P/N 6436 K74). It came cut in hallf held by two screws. Each half of the collar was countersunk on the inside curve and drilled for 1/4-28 bolt.The tubing was 1/2" OD and 0.260 ID, the perfect size from Aircraft Spruce! It was cut to length to leave room for two nuts on the end of each screw (MS24694-S119 machine screw). One nut to hold it and the second to lock it with a touch of Loctite. The tow bar piece was installed on the 1 1/4" front strut. I had planned to use 0.025 aluminum shims if the tow bar piece was too loose. No need. It pulled up tight!
The two pieces
The two pieces
Final assembly
Final assembly
Installed tow bar
Installed tow bar
