Brief Description: Setting up dimpling system and C/s cage
I finished deburring the holes in the top web and dimpled where necessary. The dimpler was set up with 2x4 blocks on each side for height adjustment. Then the dimpling went like gangbusters. A simple set up and much easier than the dimple set/nail process. The dimpling finished on the left spar, I turned to the countersinking where needed.
