Brief Description: drilling and making holes in the spar channel
The spar channels were laid out for drilling and the two oval shaped holes in each spar. I made a template to use to drill the four hole patterns in the spar channel. I used the Dremmel cut ting wheel to rough cut the holes then finished them with a file and deburred. Then I assembled the pieces to make the spar channel assembly (W13). I ordered more SNX Z01-02 needed to make the spar channel tips.
