Brief Description: Fitting Upper firewall and glare shield
I started the day test fittinig the engine mount to the corrected fuselage. Close enough for country music, I can work it from here. There are 3 brackets that connect the glare shield to the upper firewall. I clecoed the 3 brackets to test the fit. Something isn't right, I'll figure it out on the morrow. The cross tie that fits under the instrument panel (which has to be bent)and a few of the kit parts associated with it were deburred and ready to be bent. Then out for a ride along the beach!
