Brief Description: Rivet right side fuselage Ass'y
Back to work after nearly a week off. I think the last vertical channels were switched left to right. I'll think about this before I correct it.The plastic inserts for the control rods were inserted.The access hole and the slot for the rudder cable were cut in the right fuselage side. I used a Dremell cutting wheel.The screw holders for the access hole were installed. I thnk three of the four must be removed. The rivet mandrell broke above the plane of the skin. Not good.
