Brief Description: Removing twist in forward fuselage
Joohn suggested that the fwd fuse would be flexible enough to remove the twist if the spar channnel had not been rivetted, so I removed the clecoes holding the frwd channel so it was moveable. No change. The fuselage is rigid as before. The next step is to remove the channels from F09 but I want to hold off on that until I talk with John again. They didn't answer the phone yesterday or today.
