MARK'S WEB SITE
Date:  1-31-2015
Number of Hours:  6.00
Brief Description:  Doors
Had a bit of trouble with doors initially, first was reading the instructions wrong and getting the parts for the right side with the left side, need to take time and not rush things i guess.
I then assembled the doors without the perspex and a friend mentioned the bow in the centre should go towards the side were the door handle is. Looked like it made sense so I changed this around but like most things it wont fit if you do it wrong. When trying to fit the perspex it can only go one way.
Had to dis assemble and reassemble fitting the perspex. First door took quite a while but assembly of the second door took less than 60 minutes
