DAVID'S WEB SITE
Date:  8-7-2007
Number of Hours:  3.00
Brief Description:  Elevator & Trim Tab
I pulled the clecoed elevator apart in order to install the trim tab servo motor. The trim tab push rod needs to be bent to accept the control horn on either end of it. I'll need to track down some rubber grommets to protect the wiring from chafing inside the elevator. The trim tab itself was clecoed together and I epoxied the trailing edge.
